We have an Ideal C80FF "wall-mounted, gas fired, fanned flue, combination boiler" which, when working properly, is perfectly fine.
However, it goes through cycles where it trips out (usually first thing in the morning) and I have to climb into the attic to press the orange lockout button to get things going again. No pilot light on these. The light is a "failure to ignite lockout" warning.
It seems that one possibility is that when the central heating switches on in the morning that is tripping it out.
I managed to get it to do that one day whilst faffing around in the attic - SWMBO switched on the heating and tripped the cut-out.
Work done whilst we have been in residence:
• April 2006 - £250 spent on new fan unit
• August 2006 - £200 spent on new heat exchanger
Trawling through old threads ) I see that a few owners have the same problem.
The suggested causes include:
• It could be caused by many different things, faulty gas valve, fan, air pressure switch, ignition PCB etc.
• the gas valve is not set up correctly. The min/max needs to be checked but few engineers seem very competent at doing it.
• it could be anything at all to do with the combustion process and the fan/venturi would be a prime suspect.
• sludge in the secondary heat exchanger or blocked heat exchanger
• the fan venturi needs cleaning
• the dhw flow switch
• ignition control box on gas valve - common fault apparently
The question is how far do I go with the existing boiler or do I consider replacing it?
Anyone know the approx. cost of a replacement gas combi boiler supplied and fitted?
If I persevere with the current boiler and try and get a fix, do I find an Ideal boiler specialist or should any competent boiler engineer be able to find the fault?
Thanks in advance for any help and advice!
Brian
Brian
