IDEAL C80FF
24 Nov 2007
Lancashire
MY BOILER WORKS FINE WHEN ITS BEEN OFF ALL NIGHT, FOR ABOUT AN HOUR THEN GOES TO LOCKOUT. PRESS THE BUTTON WORKS FOR A SHORT WHILE THEN LOCKOUT AGAIN.DOES THIS ALLTHE TIME KEEPS GOING TO LOCKOUT.SAME WITH DHW OR CH.CHANGED THERMISTOR NO LUCK STILL SAME PROBLEM.IS IT IGNITION PCB?
normally it is the ignition board that fits into the gas valve on these that causes that problem yes
Better for a CORGI to check the fan/venturi/APS first!
Tony
