I had a Ideal HE24 installed last May. During September it started to shut down with overheat codes. After three engineering visits it was finally diagnosed that the pump was sticking and very stiff. The pump was replaced but now the problem is happening again. I am fairly sure that the pump has gone again as I can hear the system boling then shutting down suggesting that the pump isn't turning. Ideal have suggested that the level of Fernox in the might be causing the problem which I don't believe. Has anyone else had similar problems with these boilers?
Grahame
Grahame
