A
angelf
My ideal icos is making a whooping noise when it is on..any suggestions as to what the fault may be? Pipe size of gas has been increased to 22mm
When?My ideal icos is making a whooping noise when it is on..any suggestions as to what the fault may be? Pipe size of gas has been increased to 22mm
We do not advocate changing the gas valve off set at all!!!!!get an rgi in to check or reset the combustion
If wrong, replace as if you are doing it wrong (and you will be as we dont tell you how) you could increase the CO reading significantly!
If that's ideals policy, what's the justification for it, assuming the rgi onsite has an analyser?
Dig, dig, dig! You really are an angry little man with a massive fecking chip on your shoulder.We do not advocate changing the gas valve off set at all!!!!!
they want to sell more gas valves thats what! Just another example of Ideal boilers being absolute crap.
Dig, dig, dig! You really are an angry little man with a massive f*****g chip on your shoulder.
Did mummy not pay you enough attention as a child?
