Hi, My Ideal logic heat 30+, is going into L1 fault once a day. After reset, it restarts normally. The water pressure on the radiator system, is normal. The boiler would be working until going into the cooler setting overnight, but then, in the morning, I would need to go to carry out a reset, which means we wake up with house temperature too low and colder water. What would you suggest I check/do? Thank you for your help.
