Ideal Logic heat 30+ L1 fault
10 Oct 2023
Hi, My Ideal logic heat 30+, is going into L1 fault once a day. After reset, it restarts normally. The water pressure on the radiator system, is normal. The boiler would be working until going into the cooler setting overnight, but then, in the morning, I would need to go to carry out a reset, which means we wake up with house temperature too low and colder water. What would you suggest I check/do? Thank you for your help.
Thank you Harry - I'll tried this containment and see what is happening - I have reduced the boilers stat a bit below the eco position when it is always normally on. The question is, what is the actual potential rootcause? Why would it suddenly go into L1 when it has been working fine before? Water Pump? Fault sensor? Water flow obstructed in the pipework? Thank you
So, I am pleased to report that turning down the boiler's stat worked! Just still not sure why I had to do that when it was working fine until now.
It was about the size of your next gas bill.
