***Problems with my Ideal Response 80 Combi-boiler***
Just moved into a 1950's London flat which has been left empty for two years. Boiler worked and produced HW on all taps but with poor flow. Cleaned out tap ends and found lots of debris, and flow was then up to acceptable levels.
Just put in a new kitchen and modified some of the old pipework and now the boiler starts as soon as the switch is turned.
If the taps are then switch on, the boiler remains in a safe temperature range although the water seems quite hot, as though there was no flame modulation.
When the taps are switch off the boiler keeps running until it pressurises and vents.
I removed the paddle flow switch and checked it was clean and functioning. But no difference when it was replaced.
Any ideas please?
Any ideas please?
