ideal response se will not fire up
use a nail and tap it in with a hammer. easy does it :D Then when your done put this heap of poo in a skip.
its probably blocked behind the switch. Poke something in the hole. then put the terminals back where they were. Your basically linking out a safety device, very naughty mr.
HI, POKED SOMETHING IN THE HOLE BUT STILL SEEMS BLOCKED HOW DO YOU UNBLOCK THEM CHEERS ROY
ANY PARTICULAR REASON YOU'RE TYPING WITH YOUR CAPS LOCK ON?
