Hello all -
That time of year again when garden tools are taken out of their mothballs and for whatever reason are suddenly non-functional due to lack of use.
In this case it seems a microswitch for the hedgecutter handle lever has failed. The microswitch no longer springs and/or clicks and just gets stuck.
A replacement is required.
Using the model information on the side, the only obvious supply is via ebay from Hong Kong.
While this may be an option as a last resort I was hoping to find a UK supply.
http://www.ebay.co.uk/itm/10PCS-Lon...500491?hash=item237d6313cb:g:BnIAAOSwc-tY2ORi
http://www.ebay.co.uk/itm/New-Micro...m-Open-Close-Limit-Switch-KW7-3-/321207806678
Usually finding these things is about searching with the right terminology i.e the specific type of microswitch.
While KW7-2 does bring up results, it is a limited selection. Am I correct that (accorting to the image) this is rated at 4A?
The ones linked above are rated 15A. How would this affect the operation of a microswitch? Would is just be a higher rated componant but still operate the same?
View media item 99553
Any ideas?
Many thanks in advance.
Any ideas?
