Afternoon,
If anyone can help with identifying these or even better a good make / model for like size replacements, I would be most appreciative.
Think they must be imperial and they've got myson valves installed on them.
Measured sizes don't seem to fully line up with imperial or metric though. I've measured to the nearest 1/2" and for width, from outer edge of water inflow moulding to the outer edge of outflow moulding. Where the valves screw into the rad body on each side. This is practically identical dimension to edge to edge of the rad itself.
All are 24" high ~610mm.
1 is 50" or v close to.
1 is 69" or v close to.
1 is 44" or v close to.
And another 2 are 37.5"!
With the exception of the 69" none of the Mysons seem to make those widths and there isn't any 24" high (seem to be 21" then 27")!
http://www.myson.co.uk/products/premier_he.asp#tabbed-2
These need replacing and trying to minimize renewal impacts particularly to flooring. Or, I could remove and try to flush through but wouldn't be too confident they would all go back in, especially looking at the condition of the thread at valve / rad connections.
View media item 76860View media item 76861View media item 76862View media item 76863
