IEC 947-3
11 Jan 2004
Uh-oh!!
This has crept up on me today!
I have been fitting quite a few replacement boards (both Hager & Wylex) recently & the last one (Hager) I did had a BS EN 60947-3 main switch.
Today I fitted another Hager & wrote the BS EN number in the box on the EIC.
For some odd reason, I decided to look at the switch on the board & it was to IEC 947-3.....
Has this change only happened recently?
The Wylex boards (just looked in the van) still have BS EN marked switches.
As RF says, a BS std is the same as an EIC std, is just the EIC is the European one & the BS is the British one.
Both are interchangeable with each other in the UK.
Although it may not be the other way around elsewhere in Europe. :D
I think as time marches on we're all going to see more IEC numbers and fewer BS numbers.
no european standards are EN , IEC is the international electrotechical comitte.
Often the same thing will be standardised with identical or very similar documents in multiple standards system though.
