Hi
Just taken apart the waste after my wonderful wife blocked it up with tea leaves!
Problem is that having flushed the system with acid etc, water still won't drain properly unless I raise the flexible pipe running from the inaccessible "U-Bend" above the exit pipe in the wall.
Do I need to replace the waste, and if so, should I replace with Ikea fittings or can I use something more "user friendly" from B&Q?
I can supply pictures if necessary, your help is appreciated.
Os
Os
