I'm feeling a bit dim.... - help with dimmer derating needed
19 Jan 2005
Hi all
Done a bit of search but just wanted to confirm what I think I found. Adam will probably know the answers!!
Tungsten filament - no need to de-rate. Is is OK to say use a 400W dimmer on a 100W single lamp? Would 250W be better?? If so, why (apart from cost)?
Mains halogen - need to derate by 50%. ie 400W dimmer would do 4x50W=200W
ELV/12V - need to use electronic transformers with a dimmer suitable for ELV (but I have also read somewhere an ordinary one will do?). Then add up the VA on the transformers plus 25%. So a 400W dimmer will do 6x50W = 300+75=375. OR, so you not have to de-rate as it is an ELV dimmer???
When I get this right, it would make a useful 'cut out and keep'....
yes, sad I know
SB
Yes, 400W is OK, but no need, unless you want to future-proof it as much as you can. You can always buy a 1 kW dimmer!!!
Most dimmers have a minimum too, usually 60W.
Yes, GU10's, derate by 50%.
With SELV, you need to look at both the dimmer mfrs and tx mfrs. Some tx's have "can be dimmed with regular dimmer" on them. If not, use a dimmer designed specifically for SELV.
And read the small print of both tx & dimmer, in case there is a leading-edge/trailing-edge issue...
Thanks folks!
Ban - what's that in english? Annoyingly City and Guilds deleted lighting from the replacement 2360 course - so now I have to educate myself elsewhere...
Cheers
SB
