I'm thinking of having builders remove a wooden floor in my living room and replace with concrete. Would skirtings need to be taken up and how long would a job like this take?
On balance is it better to leave the original traditional wooden floors in these older Edwardian and Victorian houses rather than replace with concrete?
The house I live in was built in 1902 with a solid floor back room and suspended front. Anecdotally it was perpetually a problem. Apparently originally joists rotted against the solid floor interface and so sleeper walls were added and the floor rebuilt (1950's). Airbricks only at the front, but poor circulation. When we acquired it, oversite was damp in one corner - ~18" below external ground level. Floor structure was very wormy with damp,
We discussed the options with builder and BC, and then filled it, insulated and concrete slab with service ducts cast in. Definitely the right choice. Along with insulated walls we now have a 1902 edwardian with an EPC "C" rating.
Obviously if there is an actual leak it needs repairing.
I would suggest finding out the source of the musty smell.
a solid floor might not solve.
if the musty smell is coming up from the floor void, improving the air flow will help and insulating the floor and fitting a vapour barrier will stop smells.
