Firstly, I've had a good look at this and other forums for answers to the above problem...now I'd like to lay out my situation and get specific advice. Thanks in advance.
Please check my profile for pictures of the complete setup I'm discussing below, if they don't appear in this post.A
A couple days ago my mother phoned me late in the evening to say her small tank in the loft is going crazy, and was bubbling over and overflowing to the outside of the house through the overflow pipe for around half an hour.
She has a gas boiler downstairs, and an immersion water tank upstairs.
She says that if she turns the hot water on (via the control panel pictured) and doesn't turn it off after around 15mins, then the small tank "bubbles over". I noticed that the ball had split in 2, and the tank is warped - due to boiling water this time or last time several months ago. I've changed the ball, reduced the standing water in the tank to around 4 inches (it was at the overflow level before, and the ball valve arm had not been bent to only receive a few inches, bnut rather let the cold water be near the max capacity!).
I got her to turn the hot water on via control panel and indeed after about 15 mins the small tank was receiving hot water. So switched it off and haven't used it since.
The water out of the bathroom hot tap was NOT scolding or boiling...although hot enough for a shower I guess.
I THINK I understand that the small tank is supposed to receive a small amount of hot water, and the contents expand somewhat due to warmth. But, I don't understand why it happens so quickly and without fail come 15 mins of turning hot water on.
Although the immersion tank has a plug for the top (thermostat??) she doesn't plug it in.
Everything was working fine until some time back when the immersion failed for one reason or another. A certified plumber came round and decided the red pump (??) pictured needed changing...which he did and though water was restored, its never been the same. Not that it or he caused the problem, or did anything wrong, its just how my mother retells the story. Money is VERY tight for her and i'm trying to help her out using a bit of help from you and common sense and general (decent and to good standard) DIY skills.
The large tank seems unaffected. And when the heating is on this prob;em does not happen - just a small spit of water into the small tank when switching from heating to hot water on the control panel. The major incident the other night happened after having the heating on for ages (large old house needing a lot of heat!) and then leaving the hot water turned on.
The immersion is on the low pressure system (if I even needed to say that!). Am I correct in thinking that the front (honeywell) thermostat is the OLD kind and definately needs changing regardless of the above problem, so that the auto cut off works and can be reset (hope I phrased that right).
I'm on this forum as I'd like some advice before (if at all) calling out a plumber to investigate. If its a "simple" change the 1 or 2 thermostats, then a relative is an electrician and could probably safely do that once I buy the parts. Please advise what parts to change and what for if possible.
I hope I've covered everything to give a clear picture of the setup, what's happening, and my currently level of understanding.
I welcome helpful comments, please no trolling or bad-minded personal remarks about myself or mother which will be ignored and not responded to.
