- Joined
- 16 Nov 2004
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
I am having some problems with my immersion heater. There are two heating elements one at the top and one at the bottom of the boiler. When you switch the top element on at the switch it starts to work immediately. The bottom element is on a timer and turns itself on around midnight every night (although I dont know where the timer is??, possibly an Economy7 system??)
The problem is every night when the bottom heater turns itself on the circuit breaks at the main fuse box. I'm not sure what is causing this and was hoping that someone might know. I've check the heating element and it looks fine. I've also replaced the wire from the element to the switch unit. Also I changed the switch unit about six months ago and this sorted the problem out for a while but the same thing has happened again in the last few weeks.
Any suggestions???
Any suggestions???
