In the absence of a CH boiler right now, I'm depending on an immersion heater to heat the hot water in the cylinder. The immersion is working but I'm getting no hot water. The immersion is situated on the top of the tank, down vertically into the tank.
There is a hot water vent pipe right out of the top of the tank that returns to the the cistern above, and the first few inches of this are hot. The hot water feed to the hot water pump comes off the tank about 85% up the side but never seems to draw hot water. At the weekend, before my central heating boiler gave out, hot water was fine.
What might cause this? The stat on the immersion is set to 65 degrees.
