immersion heater on a tribune 11 water cylinder
3 Nov 2007
Perthshire
i hzve just had anew cylinder fitted but evert time the water heat's -up it is not that hot on the thermo stat . on immersion there is a red triangle with +AND MINACE ETHER SIDE AND IT SAID THAT IT WAS PRE-SET AT FACTORY CAN I RE-SET THE TEMP SO I CAN GET HOTTER WATER
Old cylinders were often set at too high a temperature.
Modern cylinders are designed to store at about 55°C as this will not scald and reduces heat losses.
You should learn to use the water at 55° !
Tony
