I need to fit a timeswitch to an immersion heater which currently has a 20A DP wall switch fed from a 16A mcb in the cu. Should I fit the timeswitch before or after the wall switch? As the timer is likely to be a digital one with backup battery I guess it should go before the wall switch so it doesn't get turned off and the battery loses its charge. Is this OK or is there a reason it should go after the wall switch? Cheers, Rich
