IMMERSION HEATING SOCKET PLATE
27 Aug 2010
Sussex
Hi
Need help please - am trying to find a replacement 2 gang socket plate - it is an old style for an immersion heater, switch on left heats up half tank and the switch on the right for the full tank. Cannot find one anywhere, does anyone know where I can get one please?
- photo of old switch plate attached
thank you in advance
Steve
All the dual immersion switches i've seen for sale were designed for single backboxes. Usually they are also designed with an on off switch and then a switch to select between elements which is not what you are descibing your switch as doing.
Your best option is probablly MK grid plus (there are other grid systems but the MK one is the best known and easiest to buy bits for, different manufacturers grid systems are generally not compatible). This is a modular system where you screw a "grid" to the backbox, insert modules of your choice and then screw on a cover plate. So you can build whatever combination of switches you want (within the switches that are available in grid plus). Note that if you only want two switches on a double socket sized plate you will need to use a three module grid and plate with a blank module.
If you want indication of what the switches do there is a company called enlabel ( http://www.enlabel.co.uk/) who will engrave grid plus plates, it's a bit pricey though. You can also get grid modules with a space to insert a paper label.
This is a 2-gang socket:
Where?
I would not worry about changing that switch, I would however be very concerned about the age of your electrical installation and the likeleyhood of a rewire being necessary. Can you post a picture of your fusebox and we can tell you if there is any more cause for concern. You probably could make a new switch up from gridswitch components but you need to know whats connected to what first to be able to specify what switches are required
Nick
