- Joined
- 24 Nov 2004
- Messages
- 428
- Reaction score
- 4
- Country
I have a supply to a detached dwellinghouse that enters the property via what I believe is strictly termed an outhouse. This outhouse has separate walls & roof to the main dwelling. Outhouse was originally built as a generator-shed and solid heating fuel store. Outhouse now converted to guest bedroom +WC. But one still has to go outside of the main dwelling to get into the "annex".
I believe that the outhouse was chosen for the rising electric main because that is where the original circuits for the dwelling would have terminated (because that's where the start-o-matic would have been). (Could be wrong here - purely guesswork)
However, with a forthcoming re-wiring job, I wish to get the incoming supply repositioned, so that it breaks surface and has its master fuses, meters and MCB's on an outside wall of the main dwelling.
If an outside CU is not possible, I will put the rising supply inside the main dwelling; I will have to rewire the annex as a matter of course
The property also comprises a garage with PIR & workbench socket; presently this is fed subterranean with its own circuit. This is definitely an outhouse!
the whole property is on one phase only.
Questions!
1) the outhouse/annex that I mentioned: is this actually defined as an outhouse?
2)If so, what special regulations might apply to wiring in this location?
3) Is it possible/safe to have the supply & CU outside? I ask this because my mother *thinks* she has seen another property with this arrangement and thinks it's a very good idea...
My copy of the IEE On-site-guide is in the post, so please forgive me for gross stupidity at this point.
Questions!
