Large outhouse in need of a supply upgrade.
This is the circuit..
A 32a MCB in the main house CU protects a 6mm t&e cable
This cable goes to a 100a switch fuse.
16mm SWA from switch fuse then goes to the outhouse.
The outhouse has quite a lot of electrical equipment so the 32a MCB and 6mm cable could do with an upgrade.
I plan to take this circuit off the house cu and run a sub main. i.e. off the supply fuse
The run of 6mm2 is about 25 m
I could run a new cable, but I have been wondering about running an additional 6mm2 cable along side the 6mm2 already in place. Double up as it were.
Now, is this a bad idea, or a way of saving money and materials.
I feel a bit odd about it, but would like some opinions
