Incomplete solder join...
20 Sep 2007
Hull
Stupidly I used an old length of pipe to join to a new piece, using a solder ring coupling. Although I cleaned it, there was a slight bit of oxidation I couldn't remove which went slighly into the joint, but deepest half of the joint was clean...
Anyway the expected happened and the solder didn't flow all way round. Testing the joint it didn't leak, but theres a 1mm gap.
Any recommendations? I thought about applying super glue or an epoxy on it?
Or are you all going to say just rip it off and start again?
Thanks in advance.
You dont say what this is to be used for and how much of a problem it would cause if it leaked.
What pipe size is it?
If its 1mm gap between the pipe and the outside of the fitting then something is wrong!
Tony
Sorry, should have clarified, 1mm around the circumference, on the T to a washbasin....
You're probably right its worth starting again as it's buggin me already! The other two are a work of art (IMO, if I do say so myself), but noticed this when cleaning the joint this morning...
When it comes to soldering, cleanliness is next to godliness right?
And one other thing I wanted to know, is when joining a T, do people heat the whole joint evenly or focus on one joint then the next and so on?
When im soldering t's i usually apply heat to all three outlets at one time, but just before i solder i apply a bit more to the end im about to solder, This usually works for me ;)
I still dont know your pipe size!
If its a 22 mm fitting and you have a 1 mm gap ALL round the pipe then the pipe is only 20mm in diameter!
Are you sure you know what pipe sizes you have?
Tony
