- Joined
- 27 Jan 2008
- Messages
- 28,431
- Reaction score
- 3,455
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I know the Wilis system will heat whole cylinder, and a longer immersion will also heat more, I know renewing an immersion can rip the tank, and I would assume a pump could also circulate the water, the problem is the immersion has a 9 inch thermostat and only heats a bit at the top, so I get good weather and the water is hot, but with a couple of days of little sun so immersion not turned on, and water cold again, heated with the central heating it stays hot for 4 days, but not with electric, don't want to spend too much, what are my options?
Immersion only used when there is excess solar power, before solar panels always used the oil boiler to heat it.
