hi all, got a problem with the above tumble dryer, it is not drying anything and is just blowing cold air out. have taken the vent off and is clear, not sure what to do next. can i fix this or should i just get a new one? any help would be great. thanks
remove the rear banjo shape on the rear cover , remove the 2 screws on the heater .on the top is 2 round discs the one on the left can be reset with a safety pin there is a very little hole in the middle push a saftey pin in till you here a faint click job done .
