Indesit CIM53 Built-in Oven Service Manual?
13 Mar 2010
Anyone have a link to a service manual please? Or at least how to access the electronic timer?
Timer can't be set as the buttons are inoperative. I'm hoping just stuck/dirty & a clean will bring it back to life.
With my older stoves oven I just bypased the clock.
I took oven top off. Trace live in from socket to clock. Clock to element. Cut both and joined.
Oven worked fine but no clock..
Get help if you aren't a DIY person.
Clocks above oven with the heat can dry out electrical components or get greece in switches causing problems.
You can buy a can of electrical cleaner from places like Halfords or Screwfix. Spray on buttons to clean may fix.
Get manual from https://indesitservice.co.uk/manuals
For anyone interested in future:
With the door open, there are screws in each corner holding the oven to the cabinet frame. With those removed, pull the oven forward.
There are then six screws holding the control panel in place. Two underneath & two at the rear of either end. With those removed, the control panel is free. The timer is held to the front panel by plastic tabs top & bottom, be careful not to break them.
The issue with this one is that rather bizarrely, the buttons for setting the timer are integrated into a plastic frame. Yes, something that sits directly above the oven is made entirely of plastic. Unsurprisingly, this had distorted with the heat, locking the buttons. I've simply removed it for now & used a matchstick to set the clock once it was all back together. I'll research spares sites for a replacement, but that will presumably just deform again.
