Indesit Dryer fault
3 Aug 2006
London
Hi guys I have a Indesit ISL 70C dryer that has a fault. When switched on the fan at the back runs fine and the eat in the drum works too but the actual drum does not turn, after a while of switching it on there is a loud sqeeling sound which gets louder and louder, help would be great, thanks in advance.
Hi mate thanks for that but where is the drive belt as i've opened the top and side cover and all is visible is the drum, will it be at the bottom? thnks again
You will probably see a stripe of polished metal round the outside of the drum where the belt normally runs. To get at the belt you will find the side panels can be removed. You will also need to loosen the back or front of the cabinet so that the belt can be put round the drum.
