Hi, can anyone tell me what the 2nd and 4th light flashing code means on this dishwasher, the appliance fills as normal then empties after a few seconds of the wash cycle starting. Any info or pointers to where i can access info would be most welcome, Thanks, bt
I can't remember what this fault indicates but a common fault on this appliance is an open heater. Unplug appliance, tip it on it's side, remove base plate and meter it.
Thanks for taking the time to reply, heater not open (25ohms) both pressure switches test out ok and change over on pressure,thermostat closed as i imagine it should be,flood switch operating as it should, haven't tested the silly water metering thing yet(need the kit from work), but don't know whether that would have anything to do with problem and i think the only thing left is the programmer unless you know different! Indesit no help, they,ll send an engineer at a million pound an hour!.Once again thanks
bt
