I have fault code F15 on my washer dryer which means water not being pumped out. I have managed to get the water out of the machine and took the hose off from the pump. It was completely blocked just above the pump so I cleared the gunk and restarted the machine.
Water now flows out of the hose when I put it on the 3 minute drain cycle but as soon as the water is pumped out and the drum starts to fill with water the F15 error code comes on again. I repeated the sequence again and the identical thing happens when on the drain cycle. It will pump water out but as soon as this stops and it starts to fill up with water the error code appears.
Any ideas as to what the issue could be as I assume the pump is working OK because the water comes out of the hose at a decent flow rate.
