INDESIT W!DL126 Flashing lights 1,2 & 4
14 Jun 2011
London
1&2&4, (dryer ntc/ fan motor) F13.
Yet again I'm hoping you can help ?
This code happened previously and I fixed it by reconnecting the loose wire at the back & plugging the pins back in to ntc. (Thanks to Rocks!)
This time however, the machine is still flashing 1, 2 & 4 so is it something else or is there a specific way to reconnect loose wires to the pins ?
Anything else I should check ? Thanks so much
[/u][/b] :cry:
Bit of tape over the plug. If the lug on the side of the thermistor is snapped then a new one is needed.
Thanks for the speedy reply Rocks.
I had insulating tape, green & blue, around the pins to help the wires stay put, not sure I can see anything broken or snapped. Going to take it all apart & do it again. Fingers crossed..
Took the two connections apart again, threaded the wires through to the end of the pins that fit onto the thermistor? plug.
Really not sure if I'm threading wires in the right place as there is no indication where to attach to get correct fixing. Just threaded through to the end and hoped for the best. Should each wire be split in two or something ?
Thanks hoping .. :|
Only 2 connections on thermistor and two wires. Might need to solder them.
Hi Rocks, :(
Well, tried connecting every whichway, soldered as suggested, no joy..
At one point, all connected up again, we got down to flashing lights 3 & 4 !
But we're back to 1,2 & 4 again. I feel it is the two pins that I'm not wiring correctly before I push them onto the prongs. Once two wires connected -
do have the same function, or is one neutral ? (both are blue) What part of the prongs that I push them on do they need to be making contact with ? If poss, do you have a picture so I can see if I have the same connectors ?
Thanks so much. Here's still hoping :|
It don't think it matters which way the wires go round. The wires go onto the two silver contacts on the thermistor
Should I be attaching the wires directly to the thermistor prongs, then press plastic pin covers over ? Haven't tried that yet in case I blew up the thermistor.
Tried attaching wires directly to the thermistor, no joy. What else can I try ?
This is starting to worry me... Can the machine be reset ?
