Indesit WD12X stuck in cycle
11 Feb 2009
London
WD12X has a load of washing in. It works fine on setting 8 Daily wash but when it goes into the rinse cycle it it jams.
The light is not flashing to show an error it is just on full.
Could I have over filled it with clothes?
Any ideas how to unlock the door and get my clothes out?
Thanks.
put mc on to drain/spin does it empty .if not pump /waste pipe blocked
Not had a chance to try as I am at work.
I couldn't get the machine to go on to the rinse or spin cycles earlier today it just jams and makes a wierd noise.
pull mc out tilt back and washing up bowl under filter on the front right unscrew .when water has gone look inside the pump poss hair clips money etc.
Okay. I have turned off the machine at the mains, this released the door lock so I have my clothes out.
Tried it again without clothes the machine is still sticking between cycles. This is not due to having the Easy Iron button pressed.
I have taken out the screws from the filter. I couldn't get the filter cap out to look inside. I used a screw driver and turned the filter cap anti-clockwise water poured out but the cap is still stuck.
Is it not supposed to come out or should I be looking elsewhere for blockages. Where would I find the pump?
pull the screw filter out fully any muck inside. that is the pump assy behind it
Thanks for your help.
I eventually got the filter open it was obstructed as it was full of safety pins?? I live in a shared house! :rolleyes:
The safety pins had caused the pump motor to burn out and had to be replaced.
