Indirect Cylinder
29 Apr 2008
Croatia
Around 2018 I moved to Croatia but I had owned the house for a while as a renovation project. I designed and installed a solid fuel central heating system. It used pumped central heating with gravity hot water. That design was chosen so the hot water cylinder could act as a heat sink in the event of pump failure or electricity cuts. The problem was, the indirect cylinder never got hot using the boiler, so I had to use the immersion heater all year round. I had bought the cylinder secondhand on Ebay in UK. I used the system for a few years like that but then had a flood. The indirect coil had failed and overfilled the expansion tank for the central heating. I cut up the cylinder to see what had happened. I discovered that the coil was not one fat pipe but several thin ones, This is why it never worked, it was only suitable for fully pumped systems! I could not buy a direct replacement cylinder in Croatia so I fitted an Ariston, mains pressure indirect cylinder. This works fine with the boiler and is also better insulated than the UK cylinder.
Yes, the system water is still open vented but the hot water is now mains pressure with an expansion vessel. It meets the regulations here and in fact the plumbers merchants don't even stock parts for open vented plumbing.
