Induction hob and single oven
21 Mar 2006
Hampshire
Have an existing 45 Amp supply fitted with a double oven and gas hob running off it via a cooker switch.
Can I run Induction hob rated 7.5Kw 30 Amps and single oven rated 2.8 Kw 13 Amps form existing supply from new switch fed from same CU 45 amp supply. Can add separte plug socket to connect oven for added protection.
Also have 1 kw microwave but will run that from kitchen ring main
advice please
Many Thanks TH
