I have an infinite prime house alarm installed. I came to disarm the alarm yesterday and the keypad is completely locked up and I was unable to disarm using the main keypad. The alarm went off.
I was lucky enough to disarm it using the GSM module by texting the alarm but this was after about 5 minutes of finding the codes etc.
The keypad remains locked and none of the buttons work. I can't even get into the Installer menu.
Any suggestions on how to fix this?
I was considering opening the panel up, remove the battery backup and then turn it off at the mains to completely reset it. However I know that when you open the front panel the alarm goes off and you have to enter a code to stop it BUT I won't be able to as the keypad is locked and I don't want to rely on just the GSM sms module to stop it in case it doesn't this time.
I've got a key fob but the batteries are flat as its never been used so don't even know if it will have kept its registration to the unit if I replace the batteries? Any ideas?
If I do a full power reset will I lose all of my config and setup?
Any advise is more than welcome as I am a little stuck right now
