Infinite WSM to ADE Reson 8 Bell Box
31 May 2014
Kent
Dear forum,
I am desperate for some help with wiring for my new alarm system bell box. After many failed attempts and a ringing head my problem is:
- I have an infinite prime alarm with a wireless sounder module (inf-wsm) with the following four terminals in:
S
T
- I am trying to connect to a ADE Reson 8 bell box which has FIVE TERMINAL points:
Rtn -
Hold off +
Hold off -
Trig -
STB -
I cannot get the configuration of the wiring correct to make it sound when the control panel sends a signal. Can anyone offer advice as to how I connect the four cables to the five terminal positions to correctly install.
Many thanks
Richard
S. To. Stb -
T. To. Trig -
- To. Hold off -
+. To. Hold off
There is no tamper input so forget rtn -
Hi thanks for your quick reply. I have tried the suggested configuration and it is not activating the siren when triggered. I have an old ade bell box which has different connections and that is working fine. I am wondering if I need to connect two of the terminals together or something to create a circuit but just can seem to figure it out.
Any other advice would be greatly received.
Cheers
Richard
No , make sure the battery is connected,the jumper is not on 5 sec test, and that the tamper switch is closed...if you take out the T wire in the wireless module and touch it to the - it should ring....
