Is there anyway to reduce noise levels for inline fan with solid ducting?
It is quite Loud on medium setting manrose mf100t
From the bathroom ductinginline fans do not produce much noise - where is the sound actually coming from?
Still same issue.That sounds like the fan just sucking up air. Take the front of ceiling vent off and see what happens
No vibration. I have two of the same fans and both do same. The only problem is I can't move them further due to lack of room. One fan has at least 500mm ducting either side and other has 500 and 400 on the fan to ventI agree with Murdochchat in-line fans are normally quiet.If you put your hand on the fan or the ducting while it's running can you feel excessive vibration, that could indicate a faulty fan. Is the air intake loose in the ceiling cladding. I would not think flexible ducting would make any difference. Moving the fan further away from the intake might improve it.
Fans screwed into the shock absorber and ply sandwich but not the joists.What’s the fan screwed to?
I glued a layer of 25mm foam to some plywood then screwed the fan to that so no mechanical fastenings to the house structure at all.
NoDoes it get any quieter if you open the bathroom door?
