Good odds the kitchen tap is fed with skinny flexis and possibly a restrictor nozzle type thing. The boiler may have a restrictor in it (some brands I understand have a max flow rate of x but by default are derated either in software or hardware to x - 20% or so). The pressure/flow difference between bath tap and the rest of the house may just be down to a straight pipe run to the bath Vs a pile of elbows in the runs to everywhere else.
Bonus if you've got access where the MDPE comes in- yes my thought was to run a temp supply to the cold feed of the boiler- ideal if you can tee in just above the mdpe- and see if better mains supply gives you better dhw output.
