inspection cover.
12 Apr 2005
i am fitting a downstairs toilet and hand basin.
ive been told by building control to fit an inspection chamber.
the drain is about 1 metre below ground,how easy is it to do?
ianp808.
dig a big hole
find the drain
cut the drain
insert ic
fill in hole
worst bit is cutting in to the drain and getting the thing to seal
wouldn't recommend it as a diy job
Nope, the worst bit is finding out your not the only one on the run, just after you've cut the pipe out. :shock:
