I need to install a new exterior composite back door into a single-brick thick utility room.
What fixings should I be using ?
The frame is 4 cm thick - so I was thinking of using these which would go straight into the brick work to a depth of 6 cm - is this sufficient ?
https://www.ironmongerydirect.co.uk...ted-75x100mm-pack-100-485605#prod_description
Thanks for your counsel in advance
