this is what we have at the moment.
in the utility room we have
up stairs
but when the siemens is switched on, it heats the house and also heats the water
the switch upstairs is for water only
we do not appear to have a thermostat, our heating is manual, and turned on/off by us or by a timer system.
i have attempted to install the nest, i have made the error of thinking it would be simpler than it is..
https://imgur.com/a/ljaaKsI
https://imgur.com/a/xTlzyPA
https://imgur.com/a/JGaO07W
As you can see, there is a L & N
the L is looped through to 2, to enable 240v system
there is a second wire connected to the 2 ( aside from the loop from L )
there are 2 wires in the 4 position, one is brown and one is black
my understanding is that the 2 position is call for heat off
and the 4 is call for heat on .
but.
if you look at the nest diagrams, they use different terms
https://imgur.com/a/0zkWfng
so
can someone help me with the following.
the wiring for the nest
can someone explain the ch off ch on thing.
is call for heat off - an open system ( an open circuit)
is call for heat on - a closed circuit, thus engaging the boiler
the two wires in the 4 position, is one of them a controlling wire for the immersion system, would it be possible to wire this into a different position in the nest, so that we could control our hot water from the app
if so, would it be a case of identifying the cicuit for the boiler i.e ch on ch off , and then the remaining wire must be for the immersion.
thank you
- a ferrolli boiler
- a siemens rwb27 controller
up stairs
- there is a seperate on off switch for an immersion which provides hot water only
but.
so
thank you
