Hi this is my first ever post to this site and I have to say the info I have obtained is great.
Just bought a house and I am in the process of installing a new kitchen. I have moved a boiler already and plumbed it back in and it has gone very well.
The problem I have is the installation of the gas hob. I have no idea where to obtain the gas fittings to do the job or in fact which fittings to use.
The hob has the usual BSP tapered connector on it. I would imagine that the connector to the gas main would have to be an elbow with an end feed or compression fit on it to the pipe and a threaded connection on the other end of the elbow. Would you use a slip coupling to achieve this fit and where would you obtain this connector.
I have a habit of trying to obtain all the information before I attempt any job. I'm actually an electrician by trade but after the success I have had with redoing the water and the boiler gas I have no problem with plumbing the hob, just don't know what connector to use.
Thanks for any help.
AC
AC
