Hi. Im about to buy a mixer shower.
my cold water pressure on my existing bath/shower mixer is ok but the hot is a little slow.
I would like to install a pump also to give it a boost.
My questions are:
1) should i tee off my hot and cold water supply serving my bath taps, run an insulated 15mm pipe (copper or plastic??) up a chased out cavity in the wall to feed the new mixer valve above, or would you recommend running a seperate pipe downwards from the cold water storage tank in the loft directly above too feed the cold side of the mixer valve, and a seperate hot feed from the airing cupboard pipework six feet away. the existing pipework serving the toilet cistern,sink and bath runs in a cavity from the airing cupboard?
2) If i wanted a install a pump would it be better to house it in the airing cupboard and install it in line on a new run of hot and cold pipework before it reaches the mixer valve.
Please forgive me if my explanation is ****e or I have answered my own questions. I would appreciate some advice..Ta!
My questions are:
