Installing a shower over a bath
23 Jul 2007
Hampshire
Just moved into a new (3yrs old) house and would like to fit a shower over the bath. What things do I need to consider when choosing the type of shower? I'm beginning to think that a mixer shower would be best to save on the wiring for an electric shower. Can I run a mixer shower straight off of the bath taps? If so, which models should I look at? This would also save on the pipework I guess which sounds good to me.
I believe I have a potterton powermax boiler if that helps at all.
Webby
That would involve some pipework would it not? Are the ones that work off the taps a decent solution?
Nope ...... Theys cheap & nasty :(
Getta electric one, they are easy to fit & work a treat, well they do if you get summink decent ...... Think £300 for the shower alone
Here :shock:
Here :shock:
When I said "work off the taps" I meant a shower that feeds directly from the tap unit like the aqualisa aquamixa NOT the rubber type that you shove onto the taps themselves.
If you've only got the 85lt model you will probably run out of hot water, if you enjoy long showers.
I will check that out, thanks Baxpoti.
Edit: It is almost certainly the 85 model, but it does have a separate cylinder fitted above it. I'm not sure what that is yet! It's quite small, about the size of a plastic fuel can I guess. Is it an extra hot water cylinder?
No, this is the secondary expansion vessel
On looking at the boiler I can see that it's the 115ltr model, so that's a bonus I guess.
