Hi All
I purchased the following from screwfix http://www.screwfix.com/prods/79843...ries/Shower-Fittings/Shower-Wall-Supply-Elbow
I am now in a position to fit it which I tried over the weekend and I cant get my head around it at all.
I have a wall with a hole in and a flexi hose coming out of it which I managed to connect to the union/elbow via a 15mm pipe and compression joints.
What my problem is, is how on earth do I attach it to the wall/tiles?
The union is literally an elbow encased in a silver casing with a black rubber washer. There are no filling instructions and no screw/mounting holes.
I am slightly concerned about using no-nails to 1) hold the washer on and 2) hold the washer (with union attached) to the wall.
As a heads up, I dont have access to behind the wall, so everything has to be done from the front.
Any ideas how to fit this or should I get another verion which can be screwed to the wall?
Karl
Karl
