Hello,
I need to install new first floor joists alongside the existing joists (not sistering, just leaving old joists in). At one end the joists will sit on an internal brick wall, as the old ones do.
However at the other end the old joists sit in pockets in the inner brick skin of the external wall (brick cavity wall). My hope was to use joist hangers. However its a 1930s, and from what I can see the brickwork is rough around the edges of the pockets. It would be best if the new joists can be installed alongside existing joists, but fixing joist hanger to brick close to the existing pockets is going to be dodgy.
My question is: can i fix a timber wall plate to the brickwork between each of the old joists, and fix joist hangers to these? This option would give more flexibility with fixing points into old brick (or would it not?). How should such wall plates be fixed to the brick?
Thanks for any advice
mdj
mdj
