Hi All.
Although I am a new member I have browsed this site many times for help needed. It's only now that I've needed some advice that I have finally registered!!
I plan to install some DG units in my sons nursery and our bedroom primarily to reduce outside noise but also for all the other benefits.
I have had a couple of rough quotes from a local manufacturer to supply the windows and checked with the planning department that no planning consent is required (we live in a conservation area, but not covered by Article4).
I have now got to the point of taking accurate measurements and noticed that the replacement windows that were put in, are, I think, fixed into the original box sections. That is to say, the brickwork on the outside seems to come into the window further than inside, with a whole lot of wood on the inside.
My "main" questions are:
1) Do I need to remove the box sections to get the best performance out of DG or for aesthetics?
2) If not then would I need to fit the frames from outside in?
3) If I do indeed have to remove the boxes, is it a major job and what could I use to finish up the inside void I would create.
Sorry if I haven't given you enough info required to help. Please reply and I will do my best.
I can supply photos if it makes it any easier.
Owen
Owen
