Hi just wondering if i can have some advice installing 10mm or 12mm plastic pipe is to serve a radiator in the living room.
I plan to channel the wall fairly deep and threading the 12mm pipes into this flexible pastic conduit with a coil of 12mm so there will be no joints in the wall as such.Use conduit clips to attach withing the wall and hopefully plaster accross.
http://cgi.ebay.co.uk/5-5m-Flexible...=39:1|66:2|65:1|240:1318&_trksid=p3286.c0.m14
Would this be a suitable method? There are concrete floors all downstairs and would rather not box the pipes if i can help it.
I plan to feed two radiators using the same method tapped from 15mm tails on the flow and returns off radiator in the above rooms,would a manifold be better or just easier?
Thanks any help appreciated
