I'm replacing lead and shared mains while my kitchen floor is dug up. Got on to Severn Trent and they've sent me a document with some rather unclear regs. There's some good info elsewhere on this site, I've also found this guide that gives slightly more info than ST http://www.unitedutilities.com/Documents/1344_How_20to_20lay_20new_20pipe.pdf but still not sure on a few points:
100mm ducting - does this mean 4inch PVC soil pipe?
Sealing the ends of the ducting - can I use foam filler for this? If no, then what?
Insulating the 25mm MDPE - How thick should this be?
My builder who's doing the kitchen floor thinks the regs are ridiculous and says he'd only use 4inch pipe coming under the external wall, then nothing but the insulation in the void under the living room floor and 76mm downpipe through the solid kitchen floor. I'm inclined to agree, but the ST document says if you don't use their aproved plumbers they'll come and inspect all your work - Is this right, can anyone give general tips, or if you've done this yourself did they inspect every inch of pipe or just the bit where it meets the mains?
Thanks,
Thanks,
