I would like to install an outside light (not a floodlight... just a normal light at the front door). This light will be placed on the outside wall of either the bedroom (ground floor flat) or the living room.
My question is... do the regs require protection if i run the cable directly through the cavity and into the bedroom/living room wall?
Also could this light be connected to the ring main or must it be connected to the lighting circuit. I can see that having the outside light protected by an RCD would be a major advantage.
Your thoughts and comments are appreciated.
Chris
Chris
