I know this is covered in part on various other posts, but I just need to clarify my specific situation. I have an existing oven running on a 32amp Wylex MCB and 6mm2 cable. I want to replace the electric oven with a 3.65kw built in electric oven and add a 6.6kw electric counter top hob. I have read that providing that the cable run is no more than 20m that the 32amp MCB with 6mm2 cable can handle a maximum of 12kw. So as the 2 appliances total 10.25kw these don't need replacing. So I can add a 45amp cooker switch to which I can connect to the hob with a 6mm2 cable and then daisy chain from the hob another 6mm2 cable (providing the connector can handle the 2 cables) to the oven? Or have I misread or misunderstood anything?
